1 - 2 of 2 Posts
My clutch is getting old and needs to be replaced, its not slippin but will sooner or later. Custom pressure plates are expensive and i also wanna get a quaife. I dont want any centerforce or act clutch. I just want to buy the stock clutch but i want a clutch disc that is better, but i dont want the disc to be thicker or a different size/shape. I need a disc that is the exact same as stock just better material something stickier. Does anyone make this?
G
Guest
You should be able to get a "Disk ONLY" from any of the aftermarket companies. I know you can from centerforce....not sure if you want to go with them though.
1 - 2 of 2 Posts
