1 - 7 of 7 Posts
Check the fine print on the sidewall for maximum recommended pressures; should be somewhere around 40-44 psi...
For everyday transportation over thousands of miles, no more than 32-34 psi; the center of the tire will wear sooner than the outside edges if run constantly above that.
If you were to autocross on this combo, then the occaisional pressure bump to 40 in the front wouldn't hurt tire wear as much as the event itself would.
Terrific links!
x eleventy billion six.
1 - 7 of 7 Posts
