1 - 10 of 10 Posts
i got a CEL the other night at 83000 miles on my 2000 ZX3.
How can I narrow down what the problem is. My first thought is that it is the pre cat O2 sensor. The car seems to be running fine. If it is the O2 sensor I can change it but I looked it up in the post about CEL codes and there is a whole list of things that could be the problem. How do I narrow it down?
Thanks
or low fuel pressure, or a problem with a MAF, or a wiring issue...
there's a million solutions. generally, yeah, it tends to be an air leak or an O2 but it's pretty hard to diagnose the problem without looking at the car. you're going to have to have a scantool to diagnose that code correctly so you may as well call a shop.
about 90% of your p0171 will be a vacuum leak. Not saying thats what it is, but thats the easiest thing to check. Good luck
scott
Discussion Starter #6
How can I check for a vaccum leak?
Discussion Starter #7
I took it in to the shop today and they say it is the PCV.
does that sound right?
P0171 - System to Lean (Bank 1) The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit. For lean and rich DTCs:
1 - 10 of 10 Posts
