CFM has their performance throttle bodies in-stock and ready to ship. These are the only true high performance throttle bodys on the market. The throttle bodys feature larger inlet openings with larger throttle body blades than the factory throttle body for increase air flow. CFM throttle body offer increased throttle response with increase performance over the factory throttle body. All of the throttle bodys are CNC machined billet aluminum made in the United States. CFM offers free tech support for any of our products.
Ford Focus 00-02 Zetec Throttle body 65mm
Parts included with throttle body:
T-20 Torx bit, T25 Torx bit, T-30 Torx bit, TPS bolts, Throttle body bracket bolts, gasket, instructions and CFM Decal.
Click here for more information.
Ford Focus 03-04 Zetec Throttle body 65mm
T-20 Torx bit, T25 Torx bit, T-30 Torx bit, TPS bolts, Bracket, Throttle body bracket bolts, gasket, instructions and CFM Decal.
Ford Focus SVT 02-04 Throttle body 67mm
Note: Our throttle body features a larger 3 inch inlet, which allows for increase flow and more performance. A stock throttle body only has a 2.75 inch inlet, which is also true with any stock modified unit.
Part included with throttle body:
TPS bolts, T-30 Torx bit, T-20 Torx bit, instructions, and free CFM decal. The TPS and rubber throttle body gasket can be reused, so they are not included.
Ford Focus Duratec 2.0/2.3 Up to 2007 Throttle body 67mm
This throttle body offers the same performance as the Cosworth throttle body at a much lower price.
TPS bolts, T-20 Torx bit, instructions, and free CFM decal. The TPS and rubber throttle body gasket can be reused, so they are not included.
