1 - 12 of 12 Posts
Check this out!!! Think it\'s a good find????
Ebay Find
I offered him $100 and he agreed. Will see if it need any modification or not once it gets here, If it does I can get my buddy at Wagner motorsports to make any changes needed. Shouldn't be a problem for him as we were going to make a radiator anyways.
I change diapers now
Re: Check this out!!! Think it\'s a good find????
How is it better than stock?
maybe because the sides are made of aluminum instead of plastic? I dunno, it will probably function the same as stock though.
If the core is any larger than stock, than I think it's a great deal, especially if fitment goes ok.
Wow didn't expect all the negativity.
This is what i'm hoping for but if not i'm only out $130 and i can always resell it. Just have to wait and see.
i got one from him but it was just oem plastic thing.
no modification needed.
Special Notes: for 2.0L models, this prototype has some differences from stock mount units and may require some small mounting modifcations
Comments: high quality high performance radiator for your pocket rocket, retails for over $400!
Description: 100% aluminum radiator, Q2 (unused) tested prototype item in manufacturer's original box, some fin misalignment (no discernable damage)
Product Manufacturer: Griffin Radiator (http://www.griffinrad.com)
So this is a pre-production test fit Griffin. A few pushed in fins, and some level of mounting work to get it to fit.
Doesn't specify 2 row...the web site does say it's available
so maybe this is one.
If it's a two row...and it fits without a fuss, then definately a deal.
No negativity here, I just honestly wanted to know what it did better than stock, as it doesn't give much of a description.
The part # matches the number on Griffens site for their street model. It's not their hi performance model, but hey if their street model is "any" bigger. It's a great deal. I mean 100.00 is cheap no matter how you look at it, and like you said, you can definately resell it if necessary.
Discussion Starter #11
Well if it's only a single i guess we could cut out the center and put in a bigger core or something.
1 - 12 of 12 Posts
