1 - 4 of 4 Posts
i need to get a chip burned to somehow have more fuel pushed into the cyl. with 24 or 30lb injectors. i didnt want to get the Pro-m maf since it is a 50-50 chance apparently that it works. so is it possible to have the fuel map tweaked from the chip, and who can do it?
geoff
Are you running lean? Why do you want more fuel? The stock ECU and program will learn to use up to a 24# injector.
I'm running intake, stage II cams, exhaust, higher compression, and minor port work. I am still rich at WOT with 24# injectors.
i am going to get a head package in the very near future and want to be safe. did you just drop the injectors in or did you get a pro-m and calibrate it and a chip to run everything?
I ran for awhile with Street headers and the 24# injectors on the Stock ECU while I was waiting for other mods to happen. Just poped em in and reset the ECU. I didn't do it for performance, it was just easy to do and a bunch of people said that it wouldn't work. Oh well, it does.
1 - 4 of 4 Posts
