Hey all, please check out this thread:
http://www.focaljet.com/ubbthreads/showflat.php?Cat=&Board=UBB36&Number=669130&page=9&view=collapsed&sb=5&o=&fpart=1
It sounds like you are having the same problem I (and others) had.
A quick synopsis:
My repair order said "found clutch slave as cause, removed and replaced clutch slave and bearing assembly. replaced clutch disc and pressure plate"
Every symptom I gave them has been addressed: rattling at idle in neutral related to clutch pedal position, clutch pedal stiff after 5 or so miles of driving, and poor shifter feel.
The only depressing follow up to this is that my shifter feel has gone really notchy as of late, sticking in gear, etc so I will likely be back at the dealership soon.
