clunk just after start up...?
422 Views 5 Replies 4 Participants Last post by  kennym04
As the thread says it's just after I start it up...Seems like if my foot is completely pressed to the floor it doesn't happen...
have you ever had any problems with your starter? I believe the starter is in that area, and the starter clutch could be sticking upon disengagement once the engine flywheel actually starts to rotate
No problems with starter. This just started happening. It's starting up fine, just a clunk when car turns over. Guess I'll figure it out eventually...
Busted motor mount? But if that were the case, I'd think it would clunk more often. I had a late model accord that would clunk every time I shifted it into drive, turns out it was a motor mount that had broken.
IMRC not working right?
Well, started up the SVTF today and no clunk. It's one of those mystery noises that comes & go's at will. If it comes back I will try to troubleshoot to see if I can figure out what it was???
