clutch making me hate this car
1 reading
4.7K views 13 replies 11 participants last post by  DustyAlex
Hey everyone! I don't post very often, but coming back from dropping my son off I just had to get this off my chest. I was really disappointed to learn Ford carried over the clutch and trans from earlier models to the 2012. I owned a 2003 with a manual trans for 7 years. I never got used to this clutch, honestly I hated it. Then I learn Ford carried this setup over to this all new Focus. If I knew this before hand I wouldn't have leased this car. The clutch is inconsistent with engagement and just feels fragile. The clutch engagement is smooth sometimes but most of the time the it's "clunky" and "jerky." No matter what I do the clutch engagement doesn't feel the same every time. Is this because of it being hydraulic, does anyone else feel the same way I do? I really freaking hate this clutch and it makes me not want to drive this car. I've been driving manual trans cars for years so inexperience is not the issue. I own a 1992 mustang gt with a tremec trans and a cable clutch. This setup engages and disengages the same every time.
Hmmm, I feel the opposite. I had a 1991 Mustang GT and I daily drove it for 4yrs, actually I taught myself how to drive stick in that car. When I started driving other vehicles with hydraulic clutches it became apparent that the Mustang was hard to clutch. Sometimes I had to drive a different manual trans vehicle for a few hours, and when I got back in my car I'd have to spend a few minutes relearning how to drive my car because I had gotten used to a hydraulic clutch. Sometimes the cable would stick on the hottest days in traffic and made the clutch jerky; had a new OEM cable too.
The one in my '03 is great and I got to drive a '12 across a parking lot and nothing felt funny to me.
In my 17 years of driving manuals (only one with a cable clutch) I've found them all to be inconsistent in engagement points depending on the air temperature and moisture in the air. That said this is the best clutching/shifting MT car I feel I've ever owned.
#7 · (Edited)
I see it as a positive that the MTX-75 was carried over--it has proven to be VERY durable and reliable. My 2001 has the original clutch with 140K miles and shows no sign of slipping.
The clutch in the 2012 feels completely different than my 2001, though it is the same transmission. The 2012 is much smoother in operation, and has a much broader take-up than the 2001. This is mostly due to the dual-mass flywheel in the 2012, absorbing the force of flywheel/friction plate contact and generally making smooth shifts easier.
Having owned several vehicles with rod and cable linkage clutches, I do understand what the OP means--there is very little "feel" through a hydraulic clutch. That is something one has to get used to, and try to just use muscle memory or powertrain reaction, rather than "feel" through the clutch pedal, to operate it. My suggestion to the OP would be to try installing a stiffer rear motor mount (roll restrictor) to improve feel through the powertrain. It has provided a more direct, connected feel to mine.
I agree the clutch pedal is light and I don't mind that, but sometimes the clutch is all or nothing. I do mostly city driving and the sudden grab of the clutch is very irritating.
It's almost like there is a delay with the engagement. I don't believe there's an issue with it because my '03 was the same way. What is up with the random hanging idle
between shifts? My '88 F150 also had a hydraulic clutch and it was perfect.
There might be something wrong with your clutch or slave cylinder. I would never consider mine all or nothing. My clutch takeup is smooth and progressive. It looks like the other posters find theirs smooth also.
X2. Driven a handful of MTX75 and Getrag Focuses and never had that feeling. Each was different from the others due to wear and mileage, but consistent.
I find every Focus I've driven much easier than the 97 XJ 5speed I learned on. The 2013 ST I absolutely loved. Engaged right off the floor, felt strong, but was easy to modulate. I find my cable clutch XR MUCH harder to drive. The engagement point varies a bit, especially coming off a fast run at autocross. I stall it nearly every time I drive it after driving the Focus for a while.
Have you considered getting an upgraded lower engine mount? It seems to makes shifter feel more consistent and may help with clutch engagement as well (less motor movement in the mounts so you have a more direct feel).
#12 · (Edited)
I agree with Tbone. You may have a defective clutch master or slave cylinder.
Decades ago, in a past chapter of life, I was a Saab mechanic. Those cars were notorious for getting worn out clutch masters that did not leak to the outside where you would see the leak. The fluid would seep past the piston in the cylinder as the clutch pedal was held down resulting in a variable engagement point in pedal travel depending on how long the pedal was held down. Shifting on the go, they worked fine. Sitting at a red light with the pedal held down could result in clutch drag before the light turned green.
I have to say that the two failed Focus clutch master cylinders I have had were wetting the carpet (and my shoes) though.
If you have a slow leak in a slave cylinder, it might be hard to see due to it being inside the bell housing.
