1 - 4 of 4 Posts
My clutch pedal pad fell apart...stainless steel cover delaminated from rubber backing, rubber is shot. Ford dealer wants $32 for replacement. Anyone know if there is a similar pad available from another source??
Not with out buying a complete set. Which will cost you more then that. Is the car still under warranty? If so the part should be covered.
Out of basic warranty (46,000 miles) but have extended warranty with $50 deductible. Guess I'm giving Ford $32 for a pad that should have lasted longer.
Ranger, ask yourself why the pad fell apart!!!
maybe you've already posted this or figured it out on your own but the clutch fluid did it and corroded your rubber padding on the pedal.
Mine did this several months ago and needed a new clutch and slave cylinders.
Just figured I'd throw it out there if this is the case in your car.
1 - 4 of 4 Posts
