clutch pedal pin
8K views 5 replies 3 participants last post by  NorthWestZX3
there is a pin in the clutch pedal thats for the clutch master cylinder, mine broke off, has this happend to anyone else? it broke right on the weld! i had to stick it back in and duck tape it so it woudlnt go anywhere until i fix it the right way. im guessing welding or buying a new pedal is the only way to fix this right right way?
Mine Broke. I just got a Bolt stuck it thru the clutch, tightend it down with a nut, added a washer, clutch cable, washer then another bolt.
Been working for the past 50k miles
Same thing happened to me. I also inserted a small bolt, washer on bothe ends, wrapped the bolt in pvc tape (so no harn to plastic) and used threadlocker so it wouldn't come undone. been going strong for about 10K
