Nope, no issues at all. They idle used to be higher with the older programs, this one runs perfect in all aspects!
The engine is suppposed to idle high, it's gotta warm up the cats! Just warm up your car before you drive it cold, and you'll also save more fuel, the SVTF runs really rich when it's cold.Is anyone experiencing issues with cold start after the YRFO update. It seems to be worse now. The engin idles high and extremely rough as if there is a misfire(but no indication of a misfire) and when i start driving and shift to neutral to stop the Revs rise to 2000rpm. Now the engine runs GREAT when warm, way better than with RLA6 but this cold issue is driving me nuts.
Kurt
My car had RLA6 when I bought it. Once I had YRF0 done I could tell a difference in the way it was driving. Specifically, I could feel the DSI switch at 5000rpm instead of 6000. So I know it is YRF0.Thank god im not the only one experiencing this. Is there a chance we got RLA6 instead of YRF0?? Even though i thought my 2003 came with RLA6, maybe it had RLA2. Um could this issue maybe have something to do with the intake clamp TSB?
When they figuire out the issue post the solution. I cant afford to leave my car at the dealor for a while since im away at school and all.My dad is having the same problem with his 2003 SVT with the reflashed pcm. The car sits in the garage all night, and then has trouble starting in the morning. After it does it high rev/popping spasm, the car is fine for the rest of the day. He works at the local ford dealer, and they are trying to find a solution too.
