I changed my transmission close to 2.5 years ago (due to bad second gear syncros) and got the F2Focus turn key transmission (when they still had that) with 4.10 gears. I have the good Synthetic Ford fluid for it. Over the last few month's I have noticed a small drip (3-5 drips perhaps) on the ground were parked.
I had my Focus up on jacks on Sunday when I was changing my Tie Rod ends. I noticed that the bottom side of the transmission has a film of oil (with dirt) on the underside. Is there a common seal or leak that goes on the MTX-75? I am going to check the level of fluid on the transmission to make sure its still good (shifts smoothly and engages easily).
Could there be an oil leak between the transmission and the motor that would only get the tranny wet?
Thanks for any Help!
