1 - 11 of 11 Posts
Hi guys, this is a list of my engine and drivetrain mods that I am looking at doing. there's no way I am paying this much for this, I'll work something out to knock off about $1000 off the price, but this is a starting point.
I need any suggestions I can get. I know what driving with a stage IV clutch is like, and I'll be using this car for street and track. I haven't included intake or exhaust mods yet, nor have decided what I am doing for the port polish, bore and head grinding.
Engine
Internal
Z-tec motor custom race pistons 8.5:1 w/rings $505.00 focusparts.com
Crower rods $379.00 focus-central.com
Custom port polish & balance & grind for cams Some local shop
Custom ECU Not sure yet =)
External
Aerocharger Stage 3 Turbo charger $2,855.00 aerocharger.com
High flow intake manifold $475.00 batinc.net
FC Mass Air Meter $239.00 focus-central.com
Ford Racing Stage 3 Camshaft $345.00 batinc.net
Crower Springs/retainers $239.00 focus-central.com
Intake/Exhaust valves $228.00 focusparts.com
FC Throttle Body $279.00 focus-central.com
FC Cam Sprokets $239.00 focus-central.com
FC Crank Pulley Kit $139.00 focus-central.com
Thermostat $13.00 focus-central.com
Esslinger Steel Main Caps $225.00 overboost.com/zetec
Esslinger Head/Main Stud $265.00 overboost.com/zetec
FC 42 Pounds per Hour Fuel Injector $229.00 focus-central.com
FC High Volume Fuel Pump (225L/Hour) $139.00 focus-central.com
Ford Racing Spark Plug Wires $40.00 focus-central.com
Total $-
Drivetrain
Ford Racing Differential $675.00 focus-central.com
4.06 Gear Set $359.00 focus-central.com
Cluch Masters Stage IV Clutch $500.00 focusparts.com
Aluminum Flywheel $400.00 focussport.com
Total $1,934.00
Thanks for your advice.
peace.
RIP Jam Master Jay
buy everythin crower (get their bumpstix, not FRs) from walter aka 'focusboy' u'll do much better price-wise.
-Ult
[ 11-01-2002, 06:51 PM: Message edited by: UltegraSTI ]
dont buy from focusparts, not a jet sponsor and havent been easy people 2 deal with...u can do better on pistons. also, stage 3 cams w/a turbo...hmmm....might want 2 consult jay, p-51, turbo tom, etc on that 1
-Ult
i think most others would agree in refrainin from 4.06s w/a turbo setup. tom has these and i believe there comin out 2 he can push further down in the 12s, maybe 11s...
-Ult
I change diapers now
Ult - Can you say, Edit button?
drew, the damn edit thing stopped working, i cant edit, might b some stupid thing w/my new modifications 2 Opera browser, went back in w/IE and i can edit...
....stock 3.82s man
-Ult
Discussion Starter #9
sounds good =).. i just removed the valves and camshaft and gears.. i also had to remove the intake manifold, because after further research, (reading properly), i found out that i needed a 70mm throttle body, from a mustang.. i don't want to deal with that, so i'll stay with stock.
this is already $1500 less than I originally thought =).. thanks for your help.. any more suggestions?
just get camshafts from crower after consultin which 1s will b optimum 4 ur setup...get ur hands on a early 2000 intake manifold instead 4 now, til another ally manifold comes out w/easy install, its comin soon, ctzx3 has a ford racing 1 that he and mcnews have fit 2 a zetec head w/minor mods (think chris said that he and mcnews were usin some type of riser plate 2 align everthin and 'sleeve' it down 2 a 65mm). just do the stuff in stages 2 c how the car responds, and after u have it all setup, go spend the bread and time and take it 2 some1 like turbo tom/mike the chipguy and have it tuned, buy 1 of mike's chips and toms engine management setup 4 an AC. and then enjoy. consult those guys in the FI forum, yeah their all bickerin at each other like boys in a locker room, but they'll have the keys if ur gonna go FI.
ADD-ON: i think some1 does mains/caps, bottom end stuff 4 a better price the ess, not sure. hmmm...dont think u'll end up goin w/bigger valves, think many in here r still runnin stock valve sizes, not sure bout many of the turbo guyz, but many of the NA dudes r not. mikes chips start round 400 bux.
good luck,
-Ult
[ 11-01-2002, 07:42 PM: Message edited by: UltegraSTI ]
Discussion Starter #11
Thanks a lot..
I'll check with them.. i'm still doing reseach before anything, I already have this as a 3 stage upgrade, the turbo, and all turbo things coming at the 3rd stage... I'll probably end up getting that stuff done in about March..
1 - 11 of 11 Posts
