1 - 5 of 5 Posts
My buddy gave me his old cone filter off his car today because he wanted a differnt color. I dont have an intake and I was wondering if there is anything I can do with it? I was look at it and wanted to know if it would attach right to the MAF or is there custom piping I would have to run to make this work? Please let me know if there is anything I can do with this filter...
Discussion Starter · #2 ·
I found this pic but the thread had no explanation on how the filter is actually attached to it, anyone know?
Ho, ho, ho... Green Giant
lots of people have done this before, including me. just detach the MAF sensor from the airbox, remove the airbox and ram the filter onto the end. the rubber inlet on the filter should be able to give enough to slip around the end of the sensor. then just use a good old hose clamp to hold it in place and you're all set. realistically, most of the filters fit so tight on there that the hose clamp isn't entirely necessary, but it's a good idea. how you keep the filter from rattling around is entirely up to you. i kept the lower portion of the air box in, took out the air filter, and let the cone filter rest in/on the box. also kept the snorkel in so that it was kinda a ghetto ram air setup. makes it louder, but i didn't think there was a lot of pickup according to the old butt dyno.
Mike
Gee that car looks familiar
Thats a K&N ru2710, just slip it over the end of the MAFS and tighten down the hose clamp. That with a custom Flowmaster catback pulled down 115whp and 120wtq for me. I can't belive how much I've done since then, that was a year ago august.
Discussion Starter · #5 ·
Thanks I will try tonight once im home from work to see if it will work that easily.
1 - 5 of 5 Posts
