1 - 3 of 3 Posts
battery light is on: replaced battery with new one/disconnected battery to run on altenator and runs fine
gauge cluster: either does not start up right away and takes a min to start reading temp/rpm/speed/fuel or does not read at all
Battery light being on is NOT always a sign your battery needs replacing. It means your charging system isn't working correctly. So, it can be the battery, but it can also be the alternator or bad ground or another part in the system.
Gauge cluster - Usually it acting funny is a sign your charging system is not working well (hence your battery light).
Double check your electrical grounds?
Also, to get more helpful advice, please add what year your Focus is, the engine you have, and list any modifications that have been made to it.
its a 2006 2.0 duratec with weld-on exhaust with dual tips, aftermarket intake cone, full body kit
1 - 3 of 3 Posts
