1 - 14 of 14 Posts
first, the hose running from the block to the airbox isn't fitting good. on the airbox side it keeps coming out and i have to keep pushing it back in.
second, today when i was backing out of my driveway to go to the g2g my car started doing weird things, like a ruff idle. the wheel was shaking real bad, the hood was shaking and the block was shaking. i decided to drive on but like at the stop lights you could hear like a rattling noise.
so i get to the g2g and get some help and so a couple guys and girl was just lookin around trying to find where the rattle came from. well tiffany was like there's a spark so i cut the engine and "apparently" the spark was coming from the hose going from the airbox to the block where it was touching a nut. they also checked the plugs too.
i just dont get how a rubber hose sparks on a metal screw.
any help will be appreciated and if you need pics to help so you can get a better idea of what i'm talking about let me know.
Man you must have one seriouse short in your system! Are you sure you're not having a leak? did you tighten the coupling between the T/B and tube really good? That thing can work itself lose pretty well and I had to go gorrilla on it to make it stay put.
Maybe your Heisenberg compensator was trying to come on and take you to the future. I'd have that looked into if I were you...
Discussion Starter #4
<font size="2" face="Verdana, Arial">Nah, the tube to the TB is fine. I torqued that thing to the point where it wouldn't turn anymore. I had 2 other people torque it behind me too. I had my Dad look at it. He is thinking that loosing the clamps at the Hump Hose and sliding the unit back about a quarter of an inch and see if that will help the hose fit better. I think it will. We just can't slide it back that much more because of the snorkel still being there. I don't know of much that will give or how much you want it to give. I think a dab of super glue will be good to help the fitting stay in the airbox. I mean apparently you can tell it's because the hose is tight because it pulls at the block too.
Oh well. The Volant is def. kickass though. I think once I get a cat-back it could wake some from the dead.
<font size="2" face="Verdana, Arial">But I hit 88mph and nothing happened!
[ 03-02-2003, 08:58 PM: Message edited by: 2o*FoCusZeTec*o2 ]
Originally posted by 2o*FoCusZeTec*o2:
[QB]first, the hose running from the block to the airbox isn't fitting good. on the airbox side it keeps coming out and i have to keep pushing it back in.
QB]
<font size="2" face="Verdana, Arial">Plug the hole in the side of the volant, shorten the hose a little, and put on a $6.00 round filter on the hose from AutoZone for your crank breather instead of running to the box.
Flux capacitor? No they only put those on stainless steal, gull wing door GM hybrids. Fords have to use something else. I think it has to do with the fact that you can still open your doors even though they're locked...
I was thinking this might be a soulution to my problem as well.
I have problems getting my host to stay put in the side of the box as well.
David Anderson
Originally posted by 1BadEgg:
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by 2o*FoCusZeTec*o2:
QB]
<font size="2" face="Verdana, Arial">Plug the hole in the side of the volant, shorten the hose a little, and put on a $6.00 round filter on the hose from AutoZone for your crank breather instead of running to the box.</font><hr /></blockquote><font size="2" face="Verdana, Arial">1badegg....what does removing the vent hose and putting a filter on do....Anything inparticular..
The filter not only would look better, but it would still allow evacuation of the air/pressure from the drivetrain. All the tube does is recirculate the air back into the engine to allow positive crankcase ventilation. And no, you don't need a K&N filter for THAT. Waste of money.
Originally posted by David Anderson:
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by 1BadEgg:
QB]
<font size="2" face="Verdana, Arial">Plug the hole in the side of the volant, shorten the hose a little, and put on a $6.00 round filter on the hose from AutoZone for your crank breather instead of running to the box.</font><hr /></blockquote><font size="2" face="Verdana, Arial">1badegg....what does removing the vent hose and putting a filter on do....Anything inparticular..</font><hr /></blockquote><font size="2" face="Verdana, Arial">As Fly mentioned above, crank/engine will breath a little better, and you won't have any crap from an open air box possibly getting down in your engine. I will try to find you a pic.
<font size="2" face="Verdana, Arial">I thought you knew..... it's the Ford version of the suicide doors.
1 - 14 of 14 Posts
