1 - 2 of 2 Posts
now i have the crower stage 2 cams, but havent dynoed them yet. now with my mods (listed below) i should be roughly around 140 whp. now what if i were to match a crower 3 intake and a crower 2 exhaust. both are advertised at 392 lift. now i know i will sacrifice torque but i will gain horsepower in its place. has anyone tried this and actually dynoed it? please post dyno results if so.
geoff
Well your ratios wont quite be right... and the cam you want is only 8 degrees bigger (that isnt much) if your going to order just one cam go ahead and have them grind you a "stage 4" 236 @.050 @ .413... this cam will work with your valve springs shouldnt be any clearencing problems... your gunna recieve an extra 1-2 percent at 7000 this way.. with a 232 cam youll see 3-4 at 7000 with a 244 cam youll see 5-7 percent.. but you need bigger exhaust cams.. the bigger matching exhaust cams will net you 2-3 more percent (thats the 252 @050 duration) .. All in all unless you arnt planning for a future head swap id order the 236 244 or 252 cam.. These will go good wtih your 220 or 228 grind cams depending on which makes the 80% ratio with your head.
[ 01-18-2003, 09:38 PM: Message edited by: Travis ]
1 - 2 of 2 Posts
