Crower or Crane cams??
665 Views 10 Replies 7 Participants Last post by  biker50610
im building a head for more power and i was wondering what would be the better stage 2 cam to go with, ill also be putting on adjustable gears with it, P&P the head, and milling it down about .070.... if anyone has any input please lemme know
1 - 11 of 11 Posts
3
CFL has had both break because of manufacturing defects
Here's a Crower
Here's a Crane
Cranes use a Ford blank with their lobes. Those don't have a bolt on the shaft to hold with a wrench also. Crowers have relibility issues in Hondas. Just more info to add in making YOUR decision.
Go Crane and .070 is way to much.......
Old Thread By Travis on Milling
the link wasn't working, maybe ill try later... what do u think would be a good mill size cause im doing all the work then doing the swap
Resonable would be .03-.04ish
about how much compression would that give me around.....?
nm.... missed somethin earlier!
I'd say you'd be close to 11. A good person to ask is Tom. He always has an answer to compression question even though he's an FI guy.
.040" will give you about 1 point. From stock 9.6:1 to about 10.5:1. Thant's what I run with my stage 2s. By the way, going to stage 2 cams and miling .040" will make this an interference engine.
Even if you were to go with high comp. pistons instead of milling?
i have the stg 2 crane in mine with the head milled with a 10.5:1 and it runs great and nice power
1 - 11 of 11 Posts
