Does anyone know of someone using these cams? These are a little bit bigger than my Crane stage 2 cams and i may want to upgrade eventually. Does Crower actually even test any of these grinds or are they completely theoretical?
Specs are below
CROWER STAGE 3
Drag Race and radical Street/Strip. Requires #84170 spring kit and
compatible ECU upgrade for optimum results. Rough idle.
RPM Range: 1100 to 8000+
Advertised Duration
284 / 276
Duration @ .050"
236 / 228
Gross Lift
.414 / .393
Lobe center
112
CRANE STAGE 2
Advertised Duration
248 / 238
Duration @ .050
226 / 216
Gross Lift
410 / 385
Lobe Separation 110
Specs are below
CROWER STAGE 3
Advertised Duration
284 / 276
Duration @ .050"
236 / 228
Gross Lift
.414 / .393
Lobe center
112
CRANE STAGE 2
Advertised Duration
248 / 238
Duration @ .050
226 / 216
Gross Lift
410 / 385
Lobe Separation 110
