1 - 5 of 5 Posts
When does one need to start worrying 'bout a custom burn? with what mods?
....tek
you really dont need a custom chip until you upgrade your injectors and MAF...basically the "MIC". Other than that...there's really nothing i can think of that would require a custom burned chip..unless you want your idle raised.
<font size="2" face="Verdana, Arial">How about race header?
<font size="2" face="Verdana, Arial">That will mess with your Air/Fuel ratio, but doesn't "require" a custom burn. Just like Wedge1212 said, MAF and injectors.
You can get a custom burn anytime, with any mods. But, consider that a custom burned chip costs about $350.00 and you will need at least 2 Dyno runs (at about $100.00 a pop) to get it just right. Is it worth the $500.00 or $600.00 to gain a few HP.
Like I said, I've got one because my car WILL NOT run without one. I also have an automatic, and any chip helps that quite a bit.
1 - 5 of 5 Posts
