Re: Cylinder Head Temperature Sensor
How do I replace this sensor?
grbrgrnzx5 said:Yeah...PITA to remove the alternator. If you do need to do it, here's my suggestion list...
If you are stupid like me:
1) Disconnect and remove the dogbone from the engine
2) Prep the alternator for removal
3) Use a floor jack on the rear end of the transaxle housing and lift from as far back as you can. This should pivot the assembly forward, providing enough space for the alternator to get clear of the intake manifold, the AC lines, and the firewall.
If you are smart like one of my friends was:
1) Perform the first two steps
2) Have a couple of friends push the car while the engine is in a forward gear. This will do much the same thing without the stress of lifting on your engine/transaxle with a floor jack.
Sounds like you have a fun job ahead of you.
Have you ever had any problems with the passenger side half-shaft components after that? I ask, because it seems like you could do some damage if you jack it too far. How do you know where to quit?BUR_ZX3 said:I disconnect both the rear tranny mount and the passenger side mount and jack the hell outta the engine to get that bad boy to come out.
Why not take the alternator out thru the top? I have only had experience with replacing the alternator on two cars and both times it was taken out thru the top.BUR_ZX3 said:The issue is the clearance between the side and the alternator in my experience.
