1 - 3 of 3 Posts
Hey forum, i own a 2009 ford focus se, it has a pretty bad knock, first place i looked were the cylinder heads, did a compression test on all four and found cylinder 4 to be dead. Its running approximately 90psi bs the other three at around 215 to 230psi. Is the dead cylinder worth fixing, and could that be a possible cause for the engine to be knocking like it is? Any help will be greatly appreciated!
2007 Focus ST 2.5L Swap
These motors really aren't worth too much, which is a good thing because it'll probably be cheaper to just replace with a used one.
1 - 3 of 3 Posts
