Are you sick of the defroster switch turning on your a/c (not all foci do this) But if you have one that does it and you hate it LIKE ME then heres how you can fix it in less than ten minutes.
Remove the radio using a ford tool (or a bent coathanger for you mcgyver like folks out there)
Then undo the four (I beilive 8mm) bolts that hold the radio bezel on (just so you can see better, you prob can do this without removing it)
Your heating and air conditioning panel consists of 3 knobs, the left is the temp of the air, the center controls where the air goes, and the right controlls the speed of the blower fan. The middle knob (the one that controls where your air is going ie... defrost, panel, floor) has a little GREY square plug on the back of it.
Unplug the little grey square plug on the back of the middle knob, and wrap it in electrical tape (prob not necissary but just for safety)
Start your car, and turn the fan on full blast, then turn the middle knob to defroster and back a few times to make sure that the a/c doesnt kick on. If it doesnt then YOUR DONE(well after you put it back together) and if it does then either you did something wrong or your car is different then mine!!!
Be carefull and enjoy the stress reliever that ford just seemed to not think about.
SORRY I EDITED THIS POST BECAUSE STUPID ME HAD TOLD YOU TO DISCONNECT THE LIGHT PLUG, IM NOT SURE WHAT HAPPENED IN MY HEAD PERHAPS A BRAINFART SO I APPOLOGISE
ITS CORRECT NOW
ITS CORRECT NOW
