1 - 15 of 15 Posts
What are so special about these plugs? What benefits would I get for spending 12.99 each instead of just buying Bosch Platinums? Any performanc difference or they just last longer?
They will last longer for the most part. thats what makes it worth it.
They also make a brighter spark. this does not make a notice difference power wise. it does make for a more cleaner burning efficient engine. your major notice will be a smoother idle.
They do not last longer. They only have a rated 30k mile life. Platinums last a lot longer. If the iridium tip was the same size as a platinum tip, then yes, it would last longer. The draw to iridiums is that the metal is a lot harder, so the point can be a lot finer, creating a hotter, more powerful spark.
I Now Post Stupid ****
SO how long are Motorcraft Platinum Finewire plugs rated to last? The tips on those is super thin compared to regular platinum.
Not Special Enough
My denso iridiums were changed after 80k miles. still worked fine and inspection of the plug revealed no damage from engine or lack of spark. Only thing of note was that heat marks indicate spark was begining to initiate from one side of the plug only. (plug getting old) gas mileage went down by this time of course. My opinion on these plugs is that they arent worth the extra money because they dont provide anything beyond what cheaper plugs offer. Besides, I side gap my plugs so Id rather not take the dremel to a $12 plug.
They are RATED as having a 30k service life.
And if gas milage was going down, that's a sign of lack of spark...
Not Special Enough
I know. I wrote that there was evidence spark was starting to creep to one side. I also didnt mean to infer promotion of denso as a long life plug.
Just a note: Don't use Bosch Platinums with forced induction! Especially the +2 and +4 versions; they'll break apart under boost.
Last thing you'll want is pieces of metal flying around in the combustion chamber.
I don't know if this applies to other brands of platinum, but just something to avoid in the future if you plan to go the FI route.
Don't use the BOSCH gimmick plugs. The are also to short for our motors. Just go with the motorcraft or autolite double platinum.
I run MotorCraft AZFS22C's, most of us FI guys run them and several of the NA SVTers do as well.
Copper core, and you can get a set of 4 for around $17
Discussion Starter #15
Awesome. Thanks everyone
1 - 15 of 15 Posts
