Well, I pretty much spent all weekend playing with my car to increase the fuel pressure and I got mixed results.
First, I installed the fuel pressure gauge. This went fine, and it was a good thing that Jim gave me a 5th injector setup cause the plate for the fuel rail came in really handy to hook up the pressure gauge.
It took until about noon Saturday to get that up and running. I installed the gauge where the coin tray used to be. It will be a nice setup once I finish it.
I tested this, to see how it runs stock. It runs about 30psi at idle, 42psi at atmospheric (lugging the engine at 1500rpm before boost hits), and about 45 psi under boost. The pressure sensor is referenced to manifold pressure, that is how this happens.
I also hooked up the pressure switch to the manifold.
Next, I started trying to increase the fuel pressure.
I was splicing into the wires of the computer by finding the right wire (Pin 63) for the signal from the fuel pressure sensor, and cut it then put connectors on the ends. The circuit connects to the connectors, and I can easily return to stock by taking out the circuit, and reconnecting the wires by plugging the connectors together. (Do I get an award for most use of the word "connect" in a paragraph?)
I get this all going, but I broke a pin off my electronic relay, about 6pm (after all the stores close!). So I hook it up with the fuel pressure working 100% of the time, and the switch hooked up to the LED just to see how the switch works.
Turns out the switch works well, the LED comes on under boost.
BUT, the resistor mod DOES NOT WORK by interrupting the signal from the fuel pressure sensor. I started at 0 Ohms, and as I start cranking in resistance, I watch the pressure GO DOWN!!!
This is not the right wire to use. I don't understand the circuit inside the pressure sensor. I thought it was a variable resistor, but it is not. I think it is a Wheatstone Bridge or something like that. I don't understand those. It's a damn good thing I installed the fuel pressure gauge first! Otherwise I'd be in trouble.
Sunday morning, I go and splice into the yellow with green stripe wire from the fuel pressure sensor, and work the resistor, and VOILA that increases the fuel pressure.
I get a new relay from Radio Shack, and wire that up.
Now, I have it working as planned. The boost pressure closes the pressure switch, which trips the relay which puts the resistor into the circuit and turns on the LED. The higher the resistance the higher the pressure. I had to go up to around 450 ohms to get about 70psi under boost. It is stock pressure at cruise and idle.
Sweet.
So I'm trying it out, and it works great. The pressure switch activates great, the only problem is it "flutters" when it is just kicking in. Because their are pressure pulses in the intake manifold. I think I can damp this out with a capacitor.
Anyway, I can run at a full 4-5psi at 70psi of fuel pressure with NO DETONATION. Well, there is the odd <tick> but nothing to worry about.
BUT...
This morning, the whole thing started acting wonky.
The idle fuel pressure was 40psi. And when I get in the boost, the circuit is working but the pressure sometimes doesn't go over 50!
It's kinda sometimes it works, sometimes it doesn't. I don't get it.
For a while I was getting only 50psi at full boost. Then, I turned the resistance to zero, and floored it. All the fuel pressures go back to normal. I turn the resistance back up, and the fuel pressure goes up and no detonation again...
I think the computer somehow "figures out" what is going on, and is compensating by turning the pressure. But how could it...?
I'm going to check my circuit tonight. Make sure nothing is wrong. Then, I'll try the fifth injector setup.
I hope that works, cause it's pretty frustrating.
Sweet.
BUT...
