1 - 3 of 3 Posts
anyone direct me to any info pertaining how to port your own throttle body? I would appreciate it greatly.
thanks
First, if you do a search, you should find some good posts about it.
Second, you want to have some of these supplies:
-A drill press or a dremel with sand paper grinders
-Some kind of High Temp Epoxy
-Lots of patience
Start with building up the back wall of your tb with the epoxy, I would use several cotes of the epoxy to be sure it is thick and strong enough.
For Saftey's sake, Let it dry overnight!
Then use your dremel or drill press w/some good grit sandpaper and gently shave off the restrictor/lip that hangs over the throttle opening.
That's pretty much it, just be sure to clean it before re-installing, you don't want plastic shavings in your engine.
i ported mine out, and i kinda wish i didnt cuz i drive in alot of traffic... but when the road opens up the throttle response is awesome!
if you have a stock one ill trade you if you pay shipping.
-j
1 - 3 of 3 Posts
