1 - 5 of 5 Posts
I've heard that it did, and if so, that sucks lol.......can anybody confirm this?
Not Special Enough
I can confirm that it does retard timing if you lose the VSS signal.
However, when the signal comes back the timing is fixed. The CEL itself is still lit. so in conclusion, the light itself dosent affect timing, just the fault condition.
ahhh I see, so if I fix the problem, but the check light doesn't go off, it won't retard timing unless the problem is there?
Not Special Enough
yep.
1 - 5 of 5 Posts
