Has anyone tried drifting in the focus, i know its a front wheel drive but its still possible.
bull ****!OmniFocus said:No matter how it is done, the results will not be in any way impressive.
:lol:sicko said:bull ****!![]()
http://rabidz.vidiac.com/category/DRIFT/0/76be4fda-25c4-4086-a48d-9855009c85eb.htm
that is ONE way to do it![]()
you said:OmniFocus said::lol:
...and what exactly does that have to do with FWD "drifing"?
......................:screwy::screwy:No.........no one has ever pulled their ebrake on their focus.....:screwy::screwy:PwRmAd said:you can use the E-brake, i was just wondering if anyone had tried it
I second that....i say a thread like this should bring an instant ban...
Good point, why would I actually want to follow the thread topic?sicko said:you didn't say anything about keeping it fwd![]()
NO IT CANT...jinstall said:Yes you can do it in a foiocus without using the hand brake. I did it Friday in the Focus right after I got the new RT615 mounted and I have no hand brake in the car. It was not on purpose either and can be done with a little practice.
http://en.wikipedia.org/wiki/Drifting_%28motorsport%29 said:Beginner techniques
These techniques don't use weight transition, so are typically the first thing the novice drifter learns.[7] However they are still used by the most experienced drifters, and require skill to execute properly. These techniques aim to induce a loss of traction on the rear wheels, either by locking the wheel (e-brake drift), or using enough power from the engine to break the traction force (power-oversteer and clutch kick).
Hand-brake or Emergency brake drift - While the clutch is depressed, the hand-brake is pulled to induce rear traction loss. As soon as traction is lost, the driver releases the clutch, depresses the accelerator, and countersteers. This technique is used heavily in drift competitions to drift large corners, or to trim the car's line mid-drift.[8]
Power oversteer or Powerslide - Often referred to by enthusiasts as "Drifting - Lite".[citation needed] It is usually done at the corner exit by stepping on the gas hard, to slide side ways out of the corner. It is most commonly employed by beginners because it teaches steering and throttle control without the danger of an actual entry oriented drift.
Nissan 240SX Shift Lock DriftingShift lock (compression slide) - Initiated by downshifting (usually from third to second or fourth to third, and using a very fast shift) instead of braking, without rev-matching, causing the drive wheels to lock momentarily. Helpful for very tight corners, allowing the driver to approach the corner at a slower speed and lower revs, while allowing quick acceleration when exiting the corner. This technique can be very damaging to the engine if mis-used as the ECU is unable to rev limit when the engine is oversped by the rear wheels. Premature downshifters are called "Rod Stretchers".[9]
Clutch kick - This is done by "kicking" the clutch (pushing in, then out, usually more than one time in a drift for adjustment in a very fast manner) to send a shock through the powertrain, upsetting the car's balance. This causes the rear wheels to slip. The foot should be at an angle so the brake and gas may be pressed as well, this being needed to control speed and stop from spinning out in the drift.
