1 - 7 of 7 Posts
as seen on FastTrax's car?
i'm pretty sure that his is a custom job.
and I've never seen one listed on any sites that are specifically zetec Focus rails that dual feed.
u could always try a universal or another car type one and try and modify it to work.
remember, Jon's car also has a fuel and engine managment that allows him to independently adjust each injector.
i dont think that you need one like that. i know the stock goes pretty far. can i ask why you need a duel feed?
Factory fuel rails can be "dual feed". Just pull the block off plate and you've got another receptacle ready to go!
'Return'(two line) Vs 'Returnless'(single line) fuel rail were used on the Zetec engines in Contour/Cougar upt to around '99 when the systems change to single line returnless.One of these early style rails should be a 'bolt on' to effect a return system with a pressure reg....
Sean Hyland fuel rail has AN fittings on both ends of it, FWIW.
Scott
1 - 7 of 7 Posts
