I thought the reason Ford(in their finite wisdom) decided to use the Daul-Mass FW was because they were using a Clutch Disc w/ a solid hub, as opposed to a sprung hub as found on any other normal car. The solid disc would result in driveline noise at low RPM's and some amount of harshness. If anyone reads SCC, and read last month's issue about the lightweight FW going onto their 350Z project car, they said that there was enough driveline noise under 2000rpm to make it sound as if the tranny was going to fall out/explode, then would disappear at above 2000rpm. I wouldn't really mind changing the FW to a lightweight version, but not at the expense of that amount of Driveline noise/vibration, and especially if I could not use the factory clutch which is said to be fairly strong(again the FW is thought to be the cause of premature clutch failure). Anyone have any input on the Clutch Disc, sprung or solid???
