1 - 17 of 17 Posts
Inheritly Sinister
I'm starting a pair of 'motivation' threads, to get people going on projects, and to help inspire more people on their engine builds. There are many different paths to make these clubs, and this will allow people to get some ideas, and choose their evil.
How it will work is this: PM to me, or any other Duratec moderator, a link to your dynograph, and include the modifications done to the engine. (you may include a link to a picture of your too if you like). We will post it in the appropriate thread so we all can revel in your engine's glory. However, to keep things civil, these threads will be locked.
So, will you join the Duratec clubs? :party:
Inheritly Sinister
Discussion Starter · #2 · (Edited)
I guess I'll have to be the first one.
Owner: Egz
Car: 2003 ZX3 2.3l
201 hp / 157 ft-lbs
4th gear pull
Supertech 11.6:1 pistons
Eagle H-beam rods
Crane stage 2 cams
Crane valve springs and retainers
Cosworth BSD
Marcy Motorsports 3-angle valve job
Cosworth intake manifold
Marcy Motorsports CAI
Cosworth header + flex
Modified Tru-Bendz 2.5" Exhaust
Tuning by Marcy Motorsport
Innovate LC-1 wideband
Ford Racing 39# injectors
Autolite 104 copper core plugs
Cosworth oil baffle
Ford Escape oil cooler
All 3 VF Engineering motor mounts
Cosworth flywheel
Clutch Masters Stage IV clutch
Quaife ATB LSD
3.82 final drive
Inheritly Sinister
Discussion Starter · #3 ·
After a new tuning session, arty joins the club!
2.3L Ranger Engine & Crank:
Eagle H-beam rods
Ported 2.0L Ranger head
Cosworth Stage 2 cams 282*/.445 lift
39lb Ford Mustang injectors
Marcy balance shaft delete kit
Modified Borla 2.5" Center Exhaust
ECU Tuning by Marcy Motorsport
Final Tuning by Joel at WPRacing.com
Inheritly Sinister
Discussion Starter · #6 ·
Welcome tb1999, who put down 213hp, 160 ft-lbs!
Member Name: tb1999
Engine: 2.3L Duratec (swapped from a 2004)
Year: 2005
Transmission: Manual (with Ford Racing 4.06 Final drive)
Modifications:
Ranger Crank
Cosworth (Carrillo) connecting Rods
Supertech (Mahle) 11.6:1 pistons.
Stock Intake and Throttle Body
Mild port work and 3 angle valve job (by me)
Custom Cams From WebCamshafts
Intake .500 lift 262 [email protected]
Exhaust .445 lift 244 [email protected]
Supertech valvesprings and retainers.
Supertech exhaust valves / Manley Intake valves.
F2 header - wrapped
Custom 3" exhaust, with Magnaflow race muffler
Exedy "Stage 0.5" Clutch Kit w/single piece steel flywheel.
Quaife ATB Differential
2.5" MAF tube.
SRI Intake made from parts of FSWerks "cool flow" intake.
EGR delete
30# injectors
Autolite 103's
Stock Coils
Upgraded timing components including 8MM chain, ranger guides, cosworth keyed crank gear, and cosworth diamond coated washers for cam gears.
Balance shaft delete
C-F-M Underdrive pulleys
ARP head and main stud kits as well as crank bolt.
F2 pan baffle kit, modified to add "trap door".
Stock 2.3L oil pump
Clevite77 bearings
Valvoline VR1 racing oil - 10W-30
hot pressures
37PSI @ idle (1450RPM)
80PSI @ 7500 RPM
Custom water-to-oil cooler from V8 Jaguar.
Stock T-Stat, Radiator, and waterpump.
All tuning done by me using SCT ProRacer package.
Complete details about this engine build can be found on that other forum:
http://www.focusfanatics.com/forum/s...d.php?t=220779
Dyno Results:
213WHP/160WTQ Pull done in 4th Gear on a Mustang Dyno
Inheritly Sinister
Discussion Starter · #8 ·
I don't think I've ever added one for my last engine I put in the Focus, so here it is:
221 hp / 162 ft-lbs
4th gear pull
Supertech 12.5:1 pistons
Eagle H-beam rods
Crower F-2372 camshafts by Massive Speed System
Cosworth BSD
Modified eBay oil catchcan
Custom short ram with 3" MAF tube
Little Caesars pizza box heat shield
Tuning by McNews Automotive
AEM UEGO wideband
Cosworth oil baffle
Exedy Flywheel
Exedy Stage 2 3-puck clutch
Quaife ATB LSD
3.82 final drive
Inheritly Sinister
Discussion Starter · #11 ·
Welcome that_odd_focus to the club!
that_odd_focus said:
I recently did a 2.3 swap in my Kona. She not completely perfect, I have to upgrade from my 2.25 exhaust to a 2.5, still have water meth injection to hook up along with putting in 30# fuel injectors since she's leaning out on stocks (I should have known better). But on stock injectors she made 201.9 whp and 146 wtq. I'll send you a link to the dyno chart.
11:1 compression Wiseco pistons, Ranger crank with Cosworth balance shaft delete and oil baffle, Eagle rods, upgraded 8mm Cosworth timing chain, gasket matched port and polish, Crower steel retainers and 250 lb valve springs, stage 2 Crane cams, Cosworth intake manifold, FSWerks race header, 2.25 TruBendz Magnaflow, K&N cold air intake, MFactory LSD, stage 1 Exedy clutch, all ARP hardware, SVT fuel pump
Hey guys I got a 07 focus with a 2.0 duratec and I got a header off a 2.3 Mazda motor that I am going to put on but on the header from the Mazda there is no place to put the top 2 o2 sensors in is there a way to delete them with out throwing a check engine light I I can put the very bottom o2 sensor in we’re it was factory on down pipe any info will help thanks
I
You'll have to install o2 bungs for them as far as I know. You can't delete those as the ECU needs them to adjust fuel.
1 - 17 of 17 Posts
