Oil Filters:
K&N HP-1002: URL
Purolator PL10241 or L10241: URL
Wix 51215: URL
NAPA: Gold 1215 (same as Wix)
Motorcraft: FL910
Amsoil: LF563
Baldwin: BT8409
Intakes:
Marcy Motorsport HI-FLO Air Intake System (Lifetime Warranty All Systems Produced) = $159
*Works on the 2.0l and the 2.3l
http://www.marcymotorsport.com/html/parts/focus_air_fuel.htm
Focus Sport Cool-Flo race air intake, with Lifetime Warranty = $179.95
http://www.focussport.com/coolflo.htm
Focus Central CAI = $139
http://www.focus-central.com/catalog/details.asp?cid=8&sid=&pid=97
Draxas ProFlow 75mm Bullet MAF kit = $285
http://store.draxas.com/store/shop.mpl?Cat=2,12,15&Item=351
K&N Typhoon CAI = $220 - $320
http://www.knfilterchargers.com/search/product.aspx?Prod=69-3512TP
F2 3" CAI Polished = $199
F2 3" CAI Raw = $189
http://www.f2focus.com/phpwcms2/index.php?_yap
Draxas is in the testing phases of an intake.
AEM plans on producing an intake in the future.
Marcy Motorsport Ported Intake Manifolds = $150, $150 core
Intake Manifolds:
Marcy Motorsport Fabricated Aluminum Sheet Metal Intake - Special Order = $1199.
Cosworth Intake Manifold = $695
http://corksport.com/main.php3?primNavIndex=0&mainURL=%2Fstore%2Findex.php3%3Fcat%3D293623
Exhausts:
Focus Sport Performance Exhaust = $299.95
http://www.focussport.com/exhaust.htm
Focus Central Cat-back = $309
http://www.focus-central.com/catalog/details.asp?cid=2&sid=&pid=94
Borla Cat-back for ZX3/ZX5 and Sedan = $479
http://www.borla.com
Magnaflow 2.25" Cat-back for ZX3/ZX5 = ~$365
http://www.magnaflow.com/02product/cat-backs/focus.htm
TruBendz Exhaust setups. 2.25" or 2.5", stainless or aluminized, choice of Borla, Flowmaster, and Magnaflow mufflers = $235-$295
http://www.trubendz.com/home.asp?producttype=exhaust&productfor=focus&pagetype=main2
Marcy Motorsport 3.0" Cat-Back, Aluminized Steel, w/resonator = Coming Soon
http://www.marcymotorsport.com/html/parts/focus_exhaust.htm
HKS Exhaust. 2.5" piping. Around August. ~$595
www.hksusa.com
Your exhaust choices are limited, since the different gas tank is larger, and Zetec exhaust setup may not fit.
Exhaust Headers:
Focus Central 4-1 Race Header (includes flex pipe) = $359
http://www.focus-central.com/catalog/details.asp?cid=2&sid=&pid=102
Draxas 4-1 Race Header (includes flex pipe) = $349
http://store.draxas.com/store/shop.mpl?Cat=2,20,27&Item=346
Marcy Motorsport Race Header - Stainless - Undergoing testing.
F2 Race Header, No Flex - $300
F2 Race Header, No Flex, Ceremic Coated - $350
http://www.f2focus.com/phpwcms2/index.php?_3gh&osCsid=
Focus Sport is in the design and testing stages of 2 different headers.
JBA is in the development stages of a header.
Draxas MIL Eliminators in design stages. ETA - soon
Draxas 4-2-1 Header in design stages.
Focus Central 2.5" Flex Pipe = $139
http://www.focus-central.com/catalog/details.asp?cid=2&sid=&pid=107
JGS Turbo Manifold flanges, for making your own turbo header = $60
http://www.jgstools.com/turbo/emf.html
Power Packages:
Cosworth d-Power Level 1: Cold air induction kit, Cast alloy intake manifold, ECU return envelope, ‘Power by Cosworth’ badge, Fitting instructions = $1195
http://www.cosworth.com/keycast/m2/m2.asp?flashversion=7&infid=54941&langid=10&sig=3
Cosworth d-Power Level 2: Pair of d-Power2 camshafts – inlet and exhaust, Tubular 4-1 exhaust header, High flow throttle body, ECU return envelope, Fitting instructions = $1195
Designed to work with Coswoth d-Power Level 1
http://www.cosworth.com/keycast/m2/m2.asp?flashversion=7&infid=54965&langid=10&sig=3
UDP:
Focus Central = $159
http://www.focus-central.com/catalog/details.asp?cid=1&sid=&pid=88
For the adventurous type who wants to experiment, the following products are for a Mazda 3, but may or may not work on the Focus. No Guarantees.
SR Motorsports Water Pump / Alternator Pulley Set = $299
SR Motorsports Complete set = $499
http://www.shaneracing.com/Mazda3_Parts.html
Throttle Body:
Focus Central 65mm = $259
http://www.focus-central.com/catalog/details.asp?cid=1&sid=&pid=92
TWM Induction 2000 series ITB - call for info
http://www.twminduction.com/ThrottleBody/ThrottleBody-FR.html
Cam Gears:
Marcy Motorsport Light Weight Cam Gear Set - $99
http://www.marcymotorsport.com/html/parts/focus_duratec_head.htm
Focus Central is currently in the development stages of an adjustible version. ~$239
Focus Sport is in design and testing stages of an adjustible version.
Camshafts:
Marcy Motorsport Daily Hi-Performance Street Use: Idle-6500RPM = $519
Marcy Motorsport Hot Street / Open Track / Drag Racing = $519
Marcy Motorsport SCCA Speed World Challenge Focus Touring Car Profile = $519
Marcy Motorsport Custom Application = $599
Piper Fast Road Duratec Cams (from 2.0 Mondeo) = £185
Other Piper cams may require aftermarket pistons
http://www.pipercams.co.uk/NewPiperWeb/redesign/NewFiles/Cams%20folder%20-%20new/Ford%20content.pdf
Focus Sport/Kent Camshafts - undergoing testing
Comp. Cams - undergoing development, ~8 months
Crower cams, 4 grinds - undergoing testing, ~2005
Crane cams, 4 grinds - undergoing testing, ~2005
Cam Tools:
Marcy Motorsport Camshaft Re-degree/Alignment Tool = $99
Focus Sport is in the development stages of a cam alignment tool.
Cylinder Heads:
Marcy Motorsport Ported Cylinder Head, Street = $400, $300 core
Marcy Motorsport Ported Cylinder Head, Race = $750, $300 core
http://www.marcymotorsport.com/html/parts/focus_cylinder_heads.htm
Head Packages:
Marcy Motorsport Daily Driver Street (Street Port, 100 Cams, Springs/Retainers, Cam Tool) = $1250.00
Marcy Motorsport High Performance Street (Street Port, 200 Cams, Springs/Retainers Cam Tool) = $1250.00
Marcy Motorsport Street/Drag Race/Open Track (Street Port, 200 Cams, Valves, Springs/Retainers Cam Tool) = $1500.00
Marcy Motorsport Sport - Drag Race/Open Track (Comp Port, 200 Cams, Valves, Springs/Retainers Cam Tool) = $1800.00
Marcy Motorsport Pro - Drag Race/Open Track (Comp Port, 300 Cams, Valves, Springs/Retainers Cam Tool) = $1800.00
Marcy Motorsport Core Charge., Refundable with return of your useable head. = $300.00
Cosworth head package is in the development stages. The kit will include the head, 'Power By Cosworth' inlet manifold, inlet/exhaust cams, larger valves, valve springs, forged piston and connecting rods as well as a recalibration of the existing ECU. ~100hp increase. ETA, Stage1, June 2004
Blocks:
Race quality, professionally assembled, balanced and blueprinted short blocks. Built from all new components including a new Ford block and crankshaft, Crower connecting rods, and ROSS Pistons.
Marcy Motorsport Balanced, Blueprinted, 13.5:1 compression (w/stock head) = $2299.00
Marcy Motorsport Balanced, Blueprinted, 12.5:1 compression (w/stock head) = $2299.00
Marcy Motorsport Balanced, Blueprinted, 11.5:1 compression (w/stock head) = $1999.00
Marcy Motorsport Balanced, Blueprinted, 10.5:1 compression (w/stock head) = $1999.00
Marcy Motorsport Balanced, Blueprinted, 8.5:1 compression (w/stock head) = $1999.00
2.3 Duratec Light Weight Crankshaft Option = $700.00
http://www.marcymotorsport.com/html/parts/focus_duratec_engine.htm
Darton 92mm Sleeves, ~$650-1000
http://www.raceeng.com/Pages/Page_10sc.html
Piston/Rods:
Circle Performance 12.5:1 Pistons, Pins & Support Rails = $184 each
Circle Performance 6.210 long Maxilite Connecting Rods = $1125 a set
Circle Performance Rod Bearings, set of 4,for OEM rods = $20
http://www.circleperformance.com/parts.htm
Marcy Motorsport Carrillo H-Beam Rods = $549
Marcy Motorsport Ross Pistons 8.5:1 w/rings = $549
Marcy Motorsport Ross Pistons 10:1 w/rings = $549
Marcy Motorsport Ross Pistons 11.5:1 w/rings = $549
Marcy Motorsport Ross Pistons 12.5:1 w/rings = $549
Cosworth Forged Connecting rods, set of 4 = $799
Cosworth Lightweight Forged piston set, 11.5:1 = $899
Marcy Motorsport Main Bearings, coming soon
Marcy Motorsport (Clevite) Rod Bearings STD, .025, .050 = $32
Marcy Motorsport Balance Shaft Eliminator kit, coming soon, ~$30
Valves:
Marcy Motorsport O.E. Ford Stock size Intake Valve = $112.00 Set of 8, $14.00 ea.
Marcy Motorsport Stainless Steel Stock size Intake Valve = $116.00 Set of 8, $14.50 ea.
Marcy Motorsport Stainless Steel 1mm Oversize Intake Valve = $116.00 Set of 8, $14.50 ea.
Marcy Motorsport Nitride Stainless Steel 1mm Oversize Intake Valve = $156.00 Set of 8, $19.50 ea.
Marcy Motorsport O.E. Ford Stock size Exhaust Valve= $132.00 Set of 8, $16.50 ea.
Marcy Motorsport Stainless Steel Stock size Exhaust Valve = $116.00 Set of 8, $14.50 ea.
Marcy Motorsport Stainless Steel 1mm Oversize Exhaust Valve = $116.00 Set of 8, $14.50 ea.
Marcy Motorsport Nitride Stainless Steel 1mm Oversize Exhaust Valve = $156.00 Set of 8, $19.50 ea.
Valve Springs:
Marcy Motorsport Progressive Valve Spring & Titanium Retainer Kit by Manton Engineering = $299
Marcy Motorsport Linear Single Valve Spring & Titanium Retainer Kit by SUPERTECH Performance Inc = $279
Marcy Motorsport Linear Dual Valve Spring & Titanium Retainer Kit by SUPERTECH Performance Inc = $299
Eibach EVS valve spring kit, 2.3 engine = $213
ECU:
Focus Sport / SCT ECU flasher - Late October / Early November.
http://www.focussport.com/chip.htm
Front strut bar:
Focus Sport front strut bar, in Red, blue and chrome = $89 - $99
http://www.focussport.com/stressbars.htm
Engine mounts:
Focus Sport VF-Engineering lower engine mount = $99
Focus Sport VF-Engineering driver-side engine mount = $135
http://www.focussport.com/mounts.htm
(same as Zetec mount)
Clutches:
Marcy Motorsport Sig. Series Sportsman Clutch Systems
Billet Steel Flywheel & Pressure Plate Combination w/ Organic Disc, 150-300hp = $849
Billet Steel Flywheel & Pressure Plate Combination w/ Rev-Lok Disc, 300-550hp = $949
http://www.marcymotorsport.com/html/parts/focus_clutches.htm
Spec Stage 1 Clutch, SF231 = $429
Spec Stage 2 Clutch, SF232 = $549
Spec Stage 3 Clutch, SF233 = $549
Spec Stage 4 Clutch, SF234 = $549
Spec Stage 5 Clutch, SF235 = $699
Spec Aluminum Flywheel = $479
http://www.specclutch.com/specMain.html
Transmission:
Marcy Motorsport MTX-75 3.82:1 Final Drive Gear Swap = $229
Marcy Motorsport MTX-75 4.06:1 Final Drive Gear Swap = $149
http://www.marcymotorsport.com/html/parts/focus_transaxle.htm
Marcy Motorsport Close Ratio Gear Set in development
Ignition:
MSD DIS-4 (rumored to work) ~$350
http://www.msdignition.com/sci_4.htm
Nology PZEV Coil-on-Plug HotWire conversion kit = ~$210
http://www.nology.com/hot.html
Nitrous:
Venom VCN-1000 kit now availible - call for pricing
Venom is in the development stages of their VCN-2000 computerized kit.
http://www.venom-performance.com/
Turbo kits:
Marcy Motorsports is in the design stages.
Focus-Power is looking for a development vehicle.
F2 is in the design/testing stages.
Supercharger kits:
Powerworks is in the testing/development states of a prototype.
K&N HP-1002: URL
Wix 51215: URL
Motorcraft: FL910
Amsoil: LF563
Baldwin: BT8409
Intakes:
Intake Manifolds:
Exhausts:
www.hksusa.com
Exhaust Headers:
Power Packages:
UDP:
Throttle Body:
Cam Gears:
Camshafts:
Cam Tools:
Cylinder Heads:
Head Packages:
Blocks:
Piston/Rods:
Valves:
Valve Springs:
ECU:
Front strut bar:
Engine mounts:
Clutches:
Transmission:
Ignition:
Nitrous:
Turbo kits:
Supercharger kits:
