1 - 20 of 30 Posts
Re: Dyno is in but.......
what where your numbers?
Yes numbers, rpm, type of turbo, cooling......DETAILS
Discussion Starter #4
One vid is of a base line of my SVT (cold air,camgear,alt pully,plugwires,JET performance module,and cat back) 171whp at 6300 rpm
the second vid is with a 70 shot from NX wet kit and pulled 233whp
I only got 62hp out of the 70 shot but still good I think
you get 171whp, NA?..
Do you have teh dyno to backup those numbers?
Does the "SAE 1.16" mean it's corrected for 16% drivetrain losses, or am I confused?
I see it was a mobile dyno type setup...since it's not there, can we assume they didn't log your air/fuel ratio? Also, is that cam gear tuned or just at 0°?
Do you have an ORP??? 171 is just unreal for a CAI, Cam Gear and Wires. If those are the only mods you have, then I'm guessing it's a relatively juiced dyno, coupled with a nice factory car!! Either way.. congrats!
I change diapers now
I'm callin BS on a baseline of 171whp for a lightly modified SVT.... those listed mods don't give 20hp....
Well can't call BS. Either he's fibbing on the mods, or that dyno is off by at least 10 more likely 15whp! But I dunno.. arguing dyno's seems hardly worth it
Correction of 1.16?? I've never seen a factor that high.
A stock SVT will average around 147 whp. With that correction it brings it to 170.5.
If they are using the old DynoJet DOS software, you can alter values to change HP readings.
Well OK I'm calling "something ain't lining up in the cosmos" instead of BS.
Discussion Starter #19
Or we can run them at the track. OR you can produce the dyno and pay for It and you can watch in person. yall can believe it or not but I proved it with the dyno sheets and I am willing to let yall watch the vids its not like it was my buddies dyno this was done at NOPI Memphis and like I said all I have is
AEM Cold Air Intake
AEM CAm Gear (advanced 4 degrees not retarded like everyone says)
AEM Alternator pulley
Taylor Plug wires
Catback Flowmaster Exhaust
Jet-peformance Module
and 70 shot from NX
Nobody said you didn't make the numbers posted.
We're just noticing that the corection factor is very high.
1 - 20 of 30 Posts
