1 - 7 of 7 Posts
i took off my air intake today to install a new TB and I found an oily mess in my intake tube. I've heard that this is from the breather tube that is attached to the valve cover. I'm going to install a breather filter on the valve cover for that so that it won't be connected to the intake anymore.
My question is whether or not I should bother trying to clean up the MAF sensor. If the TB is any indication, the MAF sensor is going to be covered in an oily film. Should I clean it, and how should I go about cleaning it up? If I don't clean it up, will there be any adverse effects since it won't be getting any worse?
do you have to re-oil the filter on the AEM? are you sure it's not from over-doing it?
Well, the oil from the breather filter should not be enough to mess up your intake tube. After about 10K miles, I had oil just enough to barely wet up the stock breather filter(=a small piece of foam)
As suggested, the oil might be comig from over-oiling the main filter. In that case, the maf can also be contaminated. But it is a real pain in the a** to clean it up...
By the way, I have the breather disconnected with a K&N breather filter attached to it for some time, and have no problems with that...
I highly suggest the breather filter. The slight bit of oil also can cause poor performance
no, the oil isn't from the breather filter... it's definitely engine oil.
If it is engine oil, it must be coming from the breather hose. As far as I know, that tube is there to balance the cranck pressure...
I hope someone with better knowledge clears out the situation, as I am really curious about it...
Your MAF sensor is not that bad to clean go to your nearest autoparts store and by some electrical cleaner in a spray can and drench the elememt. It will not hurt it, just dont put the nozle right at the element. Keep it about 6 to 8 inches away. Then alow it to dry. The cleaner should evaporate some what quickly. Since it is for electrical parts it will not leave a residue.
1 - 7 of 7 Posts
