Electrical tape peeling off and almost going into radiator fans
930 Views 2 Replies 3 Participants Last post by  Barnik
I have a 2005 with about 40,000 miles and there is a bundle of wires between the engine and the fan and it is wrapped in what looks like an electrical tape. It was peeling off and I couldn't get it to stay on. The loose end of the tape was in the fan shroud and almost touching the fan, so I cut it off.
Considering the heat seen in this area, I suspect I can't just use regular electrical tape.
Anyone else had this issue? What kind of wrapping/tape could I use to fix it?
1 - 3 of 3 Posts
electrical tape works just fine.
I would just re wrap it but do a tight back wrap first (flip the tape over and have the sticky side out) so that you can get a nice clean service to put the tape on. I would give the tape a nice tug every time you go around to get it to go tighter.
1 - 3 of 3 Posts
