1 - 18 of 18 Posts
having trouble installing my euro wrc front bumper, the top of it is alot shorter then the stock bumper even with the foam removed what else do i remove? i just took off the foam not what it is attached to do i remove this? please help!
You will likely have to cut into the crash beam on each end to fit. Look real carefully at where the bumper is making contact, then trim that away.
u well have to cut the rebar some if its like a euro bumper
Yep, gotta do some cutting, but not much. When I installed my Focus RS front bumber I cut two diagnal lines, one on either side of the rebar (I followed the shape of the frame above the bar as my guide). Basically i took a pie shaped piece off the very ends of the bar. Sorry, no pics of the final product... but you can see my posts to see how my car turned out. Best of luck.
Cheers,
-Ian
If you have an 03- the rebar is factory trimmed to fit. Just remove the foam and done. If not, do as SVT2RS has shown. Angle grinder works well to cut this, or best is to drive to a muffler shop and have them plasma or acytlene torch it out.
you will have to trim corners like was said but u may have to trim botom of impact bar also.and this stuff is hss (high strength steel) and cuts like a bear.mine ate 3 sawzall blades on 1/2 of one side finished it with a 4"grinder.
yea i would suggest finding someone w/ a plasma cutter who would be willing to do it take a lot of time and work off the process. the sawzall/grinder way takes a bit of time and work heh
i love my plasma cutter
oh please god no. please no. this reminds me when i put my euro bumper on. PITA is not even close to describing the work we went through cutting the rebar. i'll never do it again. NEVER YOU HEAR ME. NEEEVEEERRRRR!!!!!
Does anyone sell a euro front re-bar? I know you can buy the rear.
or... if u have an 01 euro bumper, cut the cups, it will clear easier, so there is less trimming required
it took me 10 min plasma cutter= teh hottness
1 - 18 of 18 Posts
