I just installed this today and it is awesome, you touch the gas and it goes, and it just wants to rev and pull like crazy. I don't see why they don't put this on at the factory becuase it make the car so much more fun to drive. It makes it real easy to spin the tires even when you don't want to now. One question for you guys though, even if you adjust the idle screw real far out or in the ECU is going to make it idle where it wants it too, right? Anyways I used the digital readout on the odometer and dialed my idle in right at 700rpm's like it was with the stock and tightened up the nut real good on it to keep it there, is that all there is too it? Thanks
