1 - 20 of 167 Posts
I'd like to try a few things for those who are going to participate in the Buttonwillow FC. I'd like to make changes to the Hdcp system to incorporate some of the alterations we talk about, but never seem to make.
Like Track Factors and Winner Penalties
I will make sure to add the new Forced Induction categories as we discussed.
However are there any other changes you think need to be made?
Also who are our past winners? Lorin, Kee and ???
Formerly focus_wrc
This would be my First FC i might go to practice as well. as HC goes i dont really know
Discussion Starter · #6 ·
Anyone see any issues with this heirarchy for power handicaps??
Naturally Aspirated
Mild Stock(ish) - 8 Base HDCP Points (SPI's)
Medium Stock(ish) - 7.5 Base HDCP Points (2.0 Liter)
Aggressive Stock(ish) - 7 Base HDCP Points (2.3 Duratecs )
Slightly Modified - 6 Base HDCP Points
Moderately Modified - 5 Base HDCP Points
Moderately Modified+ - 4.5 Base HDCP Points
Heavily Modified - 3.5 Base HDCP Points
Heavily Modified+ - 2.75 Base HDCP Points
FI Less than 200 whp
Roots FI Non-Intercooled < 200whp - 4 Base HDCP Points
Centrifugal FI Non-Intercooled < 200whp - 3.25 Base HDCP Points
Roots Intercooled < 200whp - 3.25 Base HDCP Points
Centrifugal Intercooled < 200whp - 3 Base HDCP Points
FI 200 - 250 whp
Roots FI Non-Intercooled > 200whp - 2.75 Base HDCP Points
Centrifugal FI Non-Intercooled > 200whp - 2.5 Base HDCP Points
Roots Intercooled > 200whp - 2.5 Base HDCP Points
Centrifugal Intercooled > 200whp - 2 Base HDCP Points
FI 250 - 300 whp
Roots FI Non-Intercooled > 250whp - 2 Base HDCP Points
Centrifugal FI Non-Intercooled > 250whp - 1.75 Base HDCP Points
Roots Intercooled > 250whp - 1.25 Base HDCP Points
Centrifugal Intercooled > 250whp - 1 Base HDCP Points
FI > 300 whp
Forced Induction > 300whp - 0 Base HDCP Points
Formerly focus_wrc
WOW i think that alot better that what we have right now.
how about stock SVT with intake, 65mm TB , exhuast is about 7?
Discussion Starter · #8 ·
Stock SVT is going to start at a base of 7 and with your mods (do you have an ORP?) you will probably get knocked one level to slightly modded 6.
I put Stock SVT's and Stock 2.3's in the same group.
Discussion Starter · #11 ·
Agreed, I'm going to add Auto to the Ala-Cart and I'm thinking it will add 2 hdcp points
Weight was definitely one of the issues we talked about earlier too. I think there was one more too, but I can't remember it. Were we happy with the tire HDCP's? It seems like some of the Ala-Cart HDCP's were a bit excessive too, but I can't remember which ones?
Discussion Starter · #15 ·
Weight is getting more options as well, I have also added the "track" factors, which allows you to give more or less strength to a given area based on track.
For example, streets of willow will have a factor that gives less weight to tires and engine and more to suspension, big willow will give more weight to engine and tires and keep suspension about even, buttonwillow will probably be close to a wash from what I can see. We'll see.
I've made 80% of the change, and should be able to finish the rest this weekend with ya'll to be able to configure your hdcp's again by tuesday or so as to get an idea.
HELLAFRUSH
Sweet man, thanks for the work to get this as even as possible. :thumbup:
Discussion Starter · #17 ·
The website has been updated with the new engine parameters including new weight handicaps and options and finally in the ala-cart section, there is the ability to select an automatic tranny which will give you 2 seconds back.
I have the struture for the Track Factors but I've not built them into the site yet.
But for now most people should see new handicaps, not sure they will be much closer, but at least now I think we have enough options that to get it more even will just a few adjustments here and there.
Nik is going to be prototyping a second type of system at the buttonwillow event as well, which is also very nice and might end up working better overall, so we'll see.
Lasty, I have changed FC a bit, so now you can sign up for an event without paying at the FC site. It refers anyone wanting to pay for the FC event to the Redline Track Events site.
HELLAFRUSH
Just went through it, I'm now at 6.25 points.
Althought, your weight selections read:
2200-
2200-2500
2500-2700
2700-2300
3000+
Should be 2700-3000?
Discussion Starter · #20 ·
No that's exactly how I planned it!!! :D
Otherwise would people think I'm smart... and I dont want that happening :lol:
1 - 20 of 167 Posts
