1 - 20 of 20 Posts
After some thorough testing and some track time we are proud to say that our clutch flywheel & package is going in to production. It includes a new billet steel flywheel and custom clutch that weighs in at 22.95 lbs. We were a bit concerned with how it would affect quarter-mile times but we did set a new record of 13.29 @ 100.87 this last weekend so that theory can be thrown out. Pedal effort is somewhat increased due to the increased clamping force(1800lb) but still very streetable. Look for this setup to sell for $799 in the near future.
Forgot to mention that this clutch is shifting at 8200 rpm wth no problems. This actually the main reason we began development on a new clutch setup, because those of you that race know that any of the aftermarket clutches do not shift past 7400-7600 rpm(this includes ACT, clutch masters, centerforce.)
its a billet pressure plate guys
the ONLY clutch available that ACTUALLY has an aftermarket pressure plate, unlike the rest of the clutches who just paint the stock plates
this thing has about 1800lb of clamping, and trust me, it wont slip.
It felt a bit stiffer, but a nice feeling.
The design of it is so, that even though its as light as a fidanza flywheel with stock clutch, it doesnt loose as much momentum due to weight positioning, unlike my car that looses all its momentum on shifts, hell, i cant even chirp 2nd gear(good thing boost will solve it all)
But this clutch obviously works, that guy dennis is an insane mofo, you should see this oldschooler drive, its like he has viagra for driving or something
Hell, [email protected] N/A, stock block, aint 1/2 bad
[ 11-18-2002, 01:27 PM: Message edited by: nazthug ]
Can you just buy the clutch? And NAZ you must be able to chirp 2nd ive got 80,000 miles on my stock clutch and it will spin second and chirp third sometimes.
Discussion Starter #7
<font size="2" face="Verdana, Arial">The clutch is thicker and the flywheel is thinner so they have to be sold together.
I can't wait until I get enought cash for that.. Come on Nader hook me up.. lol.. This clutch will slove all of your high rpm shifting problems. God knows I need it.
BTW Nader, what did you end up running?
Eric
Discussion Starter #9
crappy. only a 14.36 @ 90.53. Power was way off. We tuned it at 4000ft and the track was at 300ft. We added 24lb injectors and an air meter and now it pulls strong.
make that 7200rpm
POS clutches, they are all stock...crappy pressureplates, i shoulda waited for this one, who knows how long this ACT is gonna last with boost...damnit
yea that i would like to know too..
22 lbs.? Why not lighter? Or would that be a bad thing? Rotational mass sort of deal?
<font size="2" face="Verdana, Arial">9lb flywheel tends to kill momentum on shifts, the chirping youre getting is NOT power related, its everything spinning fast, and heavy
Discussion Starter #16
That is about 13-15lbs lighter than stock. I dont know if you would want to go much lighter.
Here is a pic.
BTW, this is an SFI approved setup.
I forgot you had put in a aftermarket flywheel.
Let me get this right... for $799 the kit will include a new lightweight flywheel..and everything needed to install a new clutch?? correct? not bad!!! What would be good to install while Im in there installing that? LSD and new gearing? are you running the gearing you sell on your site in your 13 sec focus??thanks!!
hey i now fc sells the final gear ratios. But as anyone used the 5th gear uprated ratio that sean hyland sells and how well does it do thanks
<font size="2" face="Verdana, Arial">Ditto here
1 - 20 of 20 Posts
