1 - 3 of 3 Posts
think we finally have it....where there was an o-ring under the fitting on the pump, we now have a metal washer in place...the original o-ring goes into a slight depression there...john realized that the surface of the pump was smooth enough, that a washer could ride on the surface..the fitting is from a mazda pump i believe and connects to the high pressure hose that goes to p/s cooler (from a mazda mvp!), then high pressure line to pipe fittings where it rejoins part of the original p/s line.
correct...twice during races in the last year or so have blown out the o-ring seal on the pump...it is no longer there...
1 - 3 of 3 Posts
