I have a ZX3 with a 1.5" drop... I did use a search but didn't come up with much. What kind of offsets can be used in this case, and is it viable to use spacer plates?
With a 1.5" drop you'll want to go between a +42mm and +48mm offset. If you plan on running 17" or 18" rims try to get a +45mm. offset. That will allow you to run a wide tire without any rubbing.
Some people get away with a +40mm. offset by using a 205mm width tire. I personally have 17" O.Z. Superleggras with a +42mm. offset. I run 215/40's and have a 1.5" drop and never rub.
+45mm will pretty much guarantee you that it will not rub. Alot of the rims out there come in +40mm offsets but you can find the right ones with a little searching.
definately, I was planning on running OZ Chronos in 17" trim with 215/45s. If the wheel doesn't come in 42mm+ offset can you use some sort of spacers? or would a smaller tire be in order, like a 205/45?
you can't use a apacer. The 40mm offset pushes the wheel out towards the fender. You would have to do the smaller tire. You can try finding a shop that would trim the hub, but I wouldn't trust that.
The Chronos come in a +42mm. offset the same as my Superleggras. You probably will not rub with a 215/45/17 but I'd go with a 205/45 or 215/40 to play it safe. What springs/dampers are you going to use?
Depending on the brand and make of tire I've heard alot of conflicting stories.
Most people experience the rubbing on the out side of the tire if there offset is too low. It is possible to roll the fenders a bit if you do get minor rubbing.
