1 - 2 of 2 Posts
I just replaced my thermostat housing and noticed alot of oil build up. I cant seem to see were its coming from. Should i get the engine steamed clean and look for the leak? I think it might of been my head gasket bolts were to loose. I checked them and they were all loose a little bit. How tight should I thighten the bolts? Im going to replace my head gasket, any info will help. Do i have to seal the gasket or just place it on and bolt it? Thanks
Of course you mean your valve cover gasket, not the head gasket, right ?
Get a new one, no sealant required. Not sure what the torque settings are.
BTW, I sell the gaskets in the OEM section of myFordPerformance.com
1 - 2 of 2 Posts
