WOW, what a snap that was!
Received my Focus Central UDP Kit from Partshopper.com ($99.95 + shipping) yesterday.
Step 1. ZX3 into Garage
2. Open beer.
3. Chock rear tires, jack and stand car and remove RF tire.
4. Swig beer.
5. Remove plastic guard covering crank pulley.
6. Loosen water pump mounting bolts.
7. Loosen crank pulley mounting bolt while helper steps on brake. (5 speed)
8. Use 15mm open end wrench to release tension (Counter-clockwise)and remove belt.
9. Remove water pump pulley and crank pulley.
10. Swig beer.
11. Grind crank pulley dust guard with Dremel.(12 to 2 and 4 to 6.)
12. Install new crank and water pump pulley.
13. Swig beer.
14. Release tension as above and install belt.
15. Tighten water pump bolts and crank pulley bolt.
16. Install plastic guard.
17. Swig beer.
18. Replace wheel and lower car.
19. Finish beer.
20. Road test with ever-widening grin!
Note: I left the alt. pulley in the box.
Tools required: 10mm wrench, 10 mm socket and ratchet, 15mm wrench, 18mm socket, breaker bar, 12oz. Mexican Beer.
Results: Increased power output thru-out RPM range.
YIPPEE!
2. Open beer.
4. Swig beer.
10. Swig beer.
13. Swig beer.
17. Swig beer.
19. Finish beer.
YIPPEE!
