Greetings. I am here looking for some assistance on getting the best handling out of a first generation Focus that we possibly can. If you have not heard of Chumpcar I will give you a brief run down on how things work. If you have, you can skip the next paragraph.
Chumpcar is a nationwide, endurance, road racing organization. They allow you to compete on tracks from Watkins Glen and Daytona in the east to Laguna Seca and COTA out west. Our shortest race this year is 7 hours in length. The longest one we have competed in was 14 hours in length. In Chumpcar each car entered is given a base value. Each performance adding piece is also given a value. The total of your base value and the additional points from parts cannot eclipse 500 points or you incur a penalty lap for every 10 points over 500. 501-510 is 1 lap in a 7 hour event, 511-520 is 2 laps, etc.
We recently got a gift from the sky. We had been a 325 point vehicle, on Monday we were told that through a new way of coming up with values, we are now a 200 point car. That means we have 125 more points to use, and I have no idea what to do with them. We are in the process of adding power through the addition of cams and the SVT header. After those two things however, there is not a whole lot we can add power wise that is either A. doable in real dollars or B. worth the points we would incur for them.
That leaves stopping and turning. Stopping is already pretty good. Besides that, the upgrades we have planned for this winter are a zero point add to our bottom line. That leaves turning.
Couple things to keep in mind:
Our current add-ons are a follows.
Stage 2 Crane cams. We need good power at a lower RPM with area under the power curve. Peaky power up in the band is just asking for us to oil down the track at some point in a 7 hour event.
Moog Front Camber Plates. Paperwork says they are for adding camber so I switched what side of the car they are on and have -2.2ish on the front end.
15x6.5 rims. They have 205/50 rubber wrapped around them. They are 8% shorter than stock, means we have a bit more dig out of the corner than we did with a stock diameter.
Interior is striped. Roll cage, FIA certified seat, 6 point harness, on-board extinguishing unit added back.
Battery moved to spare tire well.
Stock header with 2.5” exhaust from where the cat used to be back.
Put in a piece of plywood to close off the cavern of space behind the front bumper underneath the radiator.
Add-on Planned.
SVT header to 2.5” exhaust.
Wilwood replacing stock calipers front and back. Will be keeping stock rotor size so we can continue to use our 15” wheels.
All of that takes our 200 point car to 380. That leaves us with 120 points for changes and I am out of ideas. So instead of blindly making changes and hoping what I do works, I am here asking you guys. If you could do almost anything utilizing the stock attachment points, what would you recommend?
Just as an FYI here are the point values on anything suspension related.
• Purchased camber plates: 20 pts
• Homemade camber plates: 5 pts
• Shock\Strut reinforcement bar: 10 pts
• Wheel spacers: 5 pts for set of 4. Max 1.25” wide. 1/wheel
• Front sway bar: 50 pts
• Rear sway bar: 30 pts
• Super expensive shock\strut: 25 pts each
• Adjustable shock\strut: 75 pts each
• Spring that does NOT match original ID/OD (+/- 0.25”): 10 pts per corner
Any ideas\thoughts\crazy musings would be greatly appreciated.
Thanks.
We are limited to a 200TW summer tire. No slicks.
We are a low budget operation. A $4,000 solution is not really going to fly.
Two of our drivers are in their mid-50’s. They are decent but they will lose confidence and time in anything that is too skiddish.
Add-on Planned.
Thanks.
