1 - 3 of 3 Posts
Today I noticed that my fog lights did not work. They probably have not been working for a long time the only way I noticed it was when I was doing the mod light mod and notting happen no fog lights any time at all. I check the fuse number 43 in the inside fuse pannel. My question is what else could it be is there someting I am doing wrong. Fog lights are not on when on low beam or when the parking lights are one because of the mod....
check the relay in the fuse box under the hood thats what was wrong with mine, but if you were doing the fog light mod you should have been under there already, but try a new relay
actually you have to remove the relay for that mod so check and make sure you didn't fry the relay block (the thing that the relay plugs into) Thats what happend to mine i forgot, i had to cut the wire out from the block and splice some spades onto them and connect the relay underneath everything it's a PITA but if thats your prob you can fix it.
1 - 3 of 3 Posts
