For Sale: COMPLETE SVT part out! Down to the bare shell!
11K views 238 replies 99 participants last post by  ZX3TUNING
**DREW APPROVED**
****ALL QUESTIONS RELATED TO PRICES SHOULD BE TAKEN TO PM!****
******PRICES ARE IN USD******
REASONABLE PAYMENT PLAN OFFERS WILL BE ENTERTAINED
*******************SMALL ITEMS WILL NOT BE PARTED FROM PACKAGES UNLESS PURCHASER OF PACKAGES DOES NOT WANT SAID ITEMS!!****************************
Item Description: Car is a 02 Sonic Blue SVT, original 150,000KMs!
Update: All prices lowered June 19th 2011!
HANDLING:
* SVT Stock 5spokes......................$300
* Falken Eurowinter 215/45/17 tires, 3000kms on them........................$500cnd
(tires are currently on the SVT wheels right now, perfect winter setup for any focus with SVT brakes!)
EXTERIOR:
* Complete Doors: windows, motors, wiring intact minus door cards and SVT mirrors........... $400 each door
* Complete Sunroof and motor.............. $200
* Complete Hatch WITH SVT WING.................... $250
* SVT Power heated Mirrors w Sonic Blue caps.............. SOLD
* USDM Tails..................... $100
* Sonic Blue Hood................. $150
* Driver fender.............................. $70
* SVT front bumper w. Fogs/grill/skirt (has fixable damage)..........................$250
* SVT rear bumper w. rear Diffuser........................................ $250
INTERIOR:
* SVT Cluster............................... $150
* SVT AUX gauges........................ $100
* SVT cluster AND aux gauges............$200
* Audiophile sub Box with sub brackets and Amp, NO carpet...................... $100
* Complete Heater box with Fan, heater core, evaporator............... $200
* Audiophille 9006 HU................................$750
* Complete F&R seat belt assemblys.............. $100
* Dash................................ $75
* Interior carpets................................... $80
* 3x No-armrest center console............ $50each
* Cabin filter assumbly............................... $10
* Turn signal stalk..................................... $10
ENGINE&TRANS:
* SVT shifter base with OEM shifter......................... $80
* SVT shift cables .................................................$80
* CFM adjustable cam gear, black....................................... SOLD
* Spark plug wires............................................................ SOLD
* SVT intake manifold swap, includes IMRC, STOCK TB, throttle cable and Cruise control unit................ $300
* New SVT MAF(4000kms old)........................$80
* Clutchnet 12lbs Aluminum Flywheel(pre-TSB) w stock clutch(~15-20,000km)....................... $170
* VF SVT p/s mount......................... $80
MISC:
* 3x Passeneger side airbag..................... $80 each
* 2x Driver side airbag w. steering wheel..............$150 each
* Airbag control modual.............. $80
* A/C system complete: all lines, Condensor, etc...................... $150
* PS System complete: pump, lines, Rack&tierods, cooler, etc...................... $150
* Manual Pedal Swap (auto to manual swap, not pedal covers)................................... $200
* Front wiper motor assembly................. $100
* Brake master with Booster....................... $40
* Clutch master......................................... $30??
* Radiator with fans................................................. $50
SOLD ITEMS:
* Interior Wiring harness........................
SOLD
* Dash wiring harness and fuse panel with fuses .............
SOLD
* Engine Wiring harness.........................
SOLD
* front body wiring harness and fuse/realy box..............
SOLD
* ECU ignition tumbler, keys and fobs ..................................
SOLD
* Rear subframe Complete(minus brakes)............... SOLD local sale
* Falken 452 215/45/17 tires, 2000km on them......................................... SOLD Jordan O
* ST220 Shift knob............................................................................. SOLD Jon.k
* SVT Getrag Tranny.......................................................................... SOLD Bmlyes
* SVT plug wire cover........................................................................... SOLD Brain M
* AudioPhile carpeting........................................................................... SOLD Brian M
* Fuel Tank and NEW fuel pump(4000km old)............................................. SOLD James
* SVT valve cover.................................................................................... SOLD Kevin T
* Diablo Predator tuner with Serial to USB cable.......................................... SOLD Henry
* SVT MBRP 2.5" exhaust......................................................................... SOLD Otis
* SVT bottom end: Pan to head gasket...................................................... SOLD JD
* SVT Spare tire...................................................................................... SOLD JD
* Adiophile subbox, brackets and carpet ..................................................... SOLD JD
* FM Modulator........................................................................................ SOLD
* SVT hand brake complete...................................................................... SOLD Rob
* Side rear 1/4 windows........................................................................... BROKEN
* Windshield........................................................................................... BROKEN
* FS Chrome front strut bar..................................................................... SOLD Otis
* H&R Cupkit(big drop) ~65,000km with front mounts................................ SOLD JD
* Unmolested bare shell with clear title and valid VIN.................................... SCRAPPED
* Complete blue insert SVT interior(zx3) ................................................... SOLD Willie
* SVT header/Cat/Flex combo................................................................... SOLD Chuck
* OEM ST170 headlights.......................................................................... SOLD ACDetroit
* OZ Super-T's, 17x7 42et, silver, no tires................................................ SOLD CharlesWA
* Front Subframe with LCA's................................................................... SOLD James
* 02+ Euro grill...................................................................................... SOLD Otis
* SVT pedals.......................................................................................... SOLD Me
* Eibach Swaybars.................................................................................. SOLD Me
* Antenna&base..................................................................................... SOLD James
* Intermitant wiper stalk.......................................................................... SOLD James
* SVT Sideskirts..................................................................................... SOLD Mave
* SVT brake swap front and rear.............................................................. SOLD Me
* European Roof rack with Fairing............................................................. SOLD Me
* SVT glossy B-pillar and triangles............................................................ SOLD Me
Asking/Offering Price: As per each item listed above!
Email Address: PM me on here
Your Location: Vancouver BC Canada
Pics (if available):
all prices updated today!
how much for teh entire car?
I would arrange shipping, of course....(where is the car located?)
core parts already sold so whole car is not for sale unless you offer something over the top to justify the full refund of all the sold parts
Willing to separate the rear bumper diffuser?
NO! please read the post. No small items will be parted for larger packages!
:thumbup:
would u charge me for the 2 clips that hold in the pillar with the seatbelts?? lol I need those 2 clips and i cant find them anywhere
if u would, then how much for the clips, svt badge, and the 2 small moldings next to each door??
do you have the stock sub for the trunk?? if so how much seperate from the other items?
nevermind, just found out shipping accross the border is alot more than I thought.
wouldnt be worth it.
on that note....is it a sunroof car? how much for the roof liner, if it is?
ebrake cables are part of the brake swap.
bronco,
Parts arein Canada, Vancouver BC to be exact, north of Seattle. if you are in RI that would probably be a long ass drive to meet me at the boarder! :lol:
i also have no idea what parts you are after.....
#18 · (Edited)
Interested in the alternator, exhaust, and CAI...how much for a package of all three parts? How much for the alternator on its own?
Chillz,
sorry, price on the sub without the cover is the same. the carpet goes with it or in the trash.
Flea,
No problem, shoot me a PM and we can discuss!
Slower,
you want the MBRP?
i'll have to figure out a price for everything together as it will be shipping that likely kills that deal, not a package price. Not really sure what a used SVT alternator is worth, $75??
Drew,
not looking to part anything from the packages.
only way any of that will happen is if whoever buys the package doesn't want or need one of the smaller pieces.... like whoever buys the hatch, if they already have a wing or don't want it then i'll knock the cost of the wing off and sell it separately.
That goes with all of the packages/swaps.
#27 ·
Slower,
you want the MBRP?
Very interested in the MBRP. Also very interested in the alternator. $75 seems a little steep if it doesn't include shipping. $75 shipped?
ok, i will be the one to ask...
why not just put a motor in it, and sell the whole damn car? seems like a waste of a nice SVT....
lol, once all the parts are gone, it's just a zx3 shell like any other!
i don't understand the attachment to a car you don't own?!?
what's the difference from parting a nice zx3 vs selling it as a whole? value out.
might get $6500 for the car and make one person happy when you could get 10k out of the car and make 50 people happy!
i'm just doing what the owner is asking me to. it's not my place to question his wishes when he's paying me to do a job. i could honestly care less, it's just a car, it's not mint or worthy of being added to a collection, he doesn't have the stock parts to return it to stock and the part out is funding another project for him.
#29 ·
How much for the Headlight switch? The one in the dash behind the headlight knob. Pm me
