1 - 2 of 2 Posts
Why does it need to be enabled? It seems to me that after any program has been on the ecu awhile it degrades and I think its this learning bad habits function. All of the file jump when I first load them but say a week later they seem groggy and weak.
something else or learned info?
what will it do if its disabled?
If your file is good enough, you won't have an issue with it turned off. However, if it's off and the correction from short term fuel is greater or less than 25% off, you will fall into open loop operation at all times and the car will run kinda [censored] and your fuel consumption will go thru the roof. I know of a few people that are running with adaptive off.
1 - 2 of 2 Posts
