Ford Focus SVT OEM Exhaust or Aftermarket- Help me choose
1 reading
2.4K views 10 replies 4 participants last post by  lancefinney34
Hi,
I'm rebuilding a 2003 Focus ZX5 SVT for my daughter (it had a broken timing chain). I purchased a 2002 ZX3 SVT as a parts car, mainly for the cylinder head, but discovered it was equipped with a JRSC (JRSC was removed before I got it) and several other mods, including a 67mm BBK Throttle Body, OBX Header, and an aftermarket cat, resonator, muffler, and tip.
I'm not very familiar with exhaust systems, but I've read that the OBX header might cause lean issues on an untuned car due to increased flow.
My questions are:
  1. The exhaust system will fit the car I'm rebuilding, but is it safe to use without harming the engine? If so, how can I achieve a good, tolerable sound for daily driving? I was considering using the stock header with heat wrap, connecting it to the aftermarket off-road pipe, cat, resonator, and muffler.
  2. Can I install the 66mm PowePlus BBK Throttle Body without causing adverse effects to the vehicle?
Any recommendations would be helpful.
Thank you,
Lance
car.
That's an interesting setup. Someone is running an off road pipe (deletes the cat) and then put a cat further in downstream. I have no idea why they didn't just weld it into the ORP or just keep the OEM cat.
Is the OBX a 4-2-1 header or is it an SVT knockoff header? If it's a 4-2-1, it won't work unless you have a Zetec (not SVT) flexpipe. It's easy to tell what style it is because the 4-2-1 uses pretty straight primaries and the flange sits after the oil pan.
This post has been deleted
