1 - 2 of 2 Posts
If I was to get one and some cams what is available and what would you recommend. I have seen that Crower and Ford Racing both have cams avaiable are there any other than work well. I am also planning on some higher compression pistons new rods and the FR intake manifold I really wanna go all motor just because i like that route better than FI. Is there anyone on here with a lot of experience with these ztecs gonin all motor? Just some questions i tried a search but mostly it wasn't helpful. Thanks
Crower 3s
Cat 2s
FR/Crane 3s
...if u do follow thru w/a full intake (incl. manifold) and exh solution. all 3 of these will need relief work 2 get around clearance issues w/all heads. no big deal. and ur advised 2 get the head milled down 2 ur desired compression ratio. w/all of these, do not skimp, nothin short of a valvetrain upgrade. and a chip of some type 2 raise the limiter due 2 the changes ur makin that will change the engine's effective power band
-Ult
1 - 2 of 2 Posts
